Follow these steps to configure loop detection (LD) protocol globally and at the interface and VLAN level.
		  Enter global configuration mode.
			 device# configure terminal
		  Enter the
			 protocol loop-detection command to enable loop detection, enter Protocol Loop Detect configuration mode, and configure a variety of global options.
			 device(config)# protocol loop-detection
		  (Optional) Enter the
			 hello-interval command to change the hello interval from the default.
			 device(config-loop-detect)# hello-interval 2000
			 shutdown-time command to change from the default the interval after which an interface that is shut down by loop detection (LD) protocol is automatically reenabled.
			 device(config-loop-detect)# shutdown-tiome 20
			 raslog-duration command to change from default the interval between RASLog messages that are sent when a port is disabled by the loop detection (LD) protocol.
			 device(config-loop-detect)# raslog-duration 20
		   Enable LD at the interface level.
				In global configuration mode, specify an interface (either an Ethernet interface or a port-channel interface).
				  device(config)# interface ethernet 0/6
				In interface subtype configuration mode, enter the
				  loop-detection command.
				  device(conf-if-eth-0/6)# loop-detection
		  Enable LD at the VLAN level.
				In global configuration mode, create a VLAN.
				In VLAN configuration mode, enter the
				  device(config-vlan-5)# loop-detection
		  Associate the VLAN with an interface.
				  loop-detection vlan command and specify a VLAN. (The VLAN must already be created.)
				  device(conf-if-eth-0/6)# loop-detection vlan 5
		  (Optional) Disable the shutting down of an interface (Ethernet or port-channel) as a result of the loop detection (LD) protocol.
				  loop-detection shutdown-disable command.
				  device(conf-if-eth-0/6)# loop-detection shutdown-disable
		  Confirm the LD configuration, using the
			 show loop-detection command with a variety of options.
				To display LD information at the system level, enter the
				  show loop-detection command as in the following example.
				  device# show loop-detection
Strict Mode:
Number of loop-detection instances enabled: 1
Interface: eth 0/6
        Enabled on VLANs: 100
        Shutdown Disable:   No
        Interface status: UP
        Auto enable in: Never
Packet Statistics:
vlan            sent            rcvd        disable-count
100             100             0           0
Loose Mode:
Number of LD instances:   2
Disabled Ports:                   2/7
Packet Statistics:
100             100             0           0
				 To display ports disabled by LD, enter the
				  show loop-detection disabled-ports command as in the following example.
				  device# show loop-detection disabled-ports
Ports disabled by loop detection
port       age(min)       disable cause
0/6        5              Disabled by Self
				To display global LD configuration values, enter the
				  show loop-detection globals command.
			 device# show loop-detection globals
Loop Detection:                 Disabled
Shutdown-time (minutes):        0
Hello-time (msec):              1000
Raslog-duration (minutes):      10
		  Use the clear loop-detection command in privileged EXEC mode with a variety of options to reenable ports that were disabled by LD and clear the LD statistics.
				 To enable LD-disabled ports and clear LD statistics on all interfaces, enter the
				  clear loop-detection command.
				  device# clear loop-detection
				 To enable LD-disabled ports and clear LD statistics on an Ethernet interface, enter the
				  clear loop-detection interface ethernet command.
				  device# clear loop-detection interface ethernet 0/6
				To enable LD-disabled ports and clear LD statistics on a port-channel interface, enter the
				  clear loop-detection interface port-channel
				  command.
				  device# clear loop-detection interface port-channel 20
				To enable LD-disabled ports and clear LD statistics on a VLAN, enter the
				  clear loop-detection interface vlan command.
				  device# clear loop-detection interface vlan 10
