Configuring a topology group
Follow this procedure to configure a topology group. Extreme SLX devices support creating 128 topology groups in a system.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
    device(config)#
  2. Enter the topology-group command to create a topology group at the global configuration level.
    device(config)# topology-group 1
    device(conf-topo-group-1)#
    The no topology-group command deletes an existing topology group.
