Configuring basic RSTP parameters
Follow these steps to configure basic RSTP parameters.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enable RSTP.
    device(config)# protocol spanning-tree rstp
  3. Designate the root device.
    device(conf-rstp)# bridge-priority 28582
  4. Enable the error disable timeout timer value.
    device(conf-rstp)# error-disable-timeout enable
  5. Configure the error-disable-timeout interval value.
    device(conf-rstp)# error-disable-timeout interval 60
  6. Enable edge port on switch ports.
    1. Enter interface subtype configuration mode for the switchport.
      device(conf-rstp)# interface ethernet 0/10
    2. Enable edge port.
      device(conf-if-eth-0/10)# spanning-tree edge-port
    3. Return to global configuration mode.
      device(conf-if-eth-0/10)# exit
    4. Repeat the above steps for all ports that connect to a workstation or PC.
  7. Specify port priorities.
    1. Enter interface subtype configuration mode.
      device(config)# interface ethernet 0/11
    2. Configure the port priority.
      device(conf-if-eth-0/11)# spanning-tree priority 1
      device(conf-if-eth-0/11)# exit
  8. Enable the guard root feature.
    1. Enter interface configuration mode.
      device(conf-if-eth-0/1)# spanning-tree guard root
    3. Return to privileged EXEC mode.
      device(conf-if-eth-0/1)# exit
  9. Verify the configuration.
    device# show spanning-tree
    Spanning-tree Mode: Rapid Spanning Tree Protocol
    Root Id: 4096.01e0.5200.0180 (self)
    Bridge Id: 4096.01e0.5200.0180
    Root Bridge Forward Delay: 15; Hello Time: 2; Max Age: 20; Max-hops: 20
    Configured Forward Delay: 15; Hello Time: 2; Max Age: 20; Max-hops: 20
    Number of topology change(s): 0
    Bpdu-guard errdisable timeout: disabled
    Bpdu-guard errdisable timeout interval: 300 sec
    switch# show spanning-tree brief
    Root ID Priority 4096
    Address 768e.f805.5800
    Hello Time 2, Max Age 20, Forward Delay 15
    Bridge ID Priority 4096
    Interface   Role     Sts     Cost     Prio     Link-type     Edge
    Eth 0/1     DES      FWD     2000     128      P2P           No
    Eth 0/10    DES      FWD     2000     128      P2P           No
    Eth 0/11    DES      FWD     2000     128      P2P           No
    Observe that the settings comply with the formula set out in the STP parameters section, as follows:
    (2 × (forward delay - 1)) ≥ maximum age ≥ (2 × (hello time + 1))
    or in this case: 28 ≥ 20 ≥ 6.
  10. Save the configuration.
Basic RSTP configuration example
device(conf-rstp)# interface etherne 0/10
