Enabling and configuring PVST+ on an interface
Follow these steps to enable and configure PVST+ on an interface.
The ports and parameters can be configured individually on a system by:
  1. Entering the commands in steps 1, and 2
  2. Running the relevant addition steps and parameter commands
  3. Verifying the result
  4. Saving the configuration
For detailed descriptions of the parameters and features, see the sections STP parameters and STP features.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enable PVST+.
    device(config)# protocol spanning-tree pvst
  3. Enter interface configuration mode.
    device(config-pvst)# interface ethernet 0/3
  4. Enable spanning tree on the interface.
    device(conf-if-eth-0/3)# no spanning-tree shutdown
  5. Configure the interface link type.
    device(conf-if-eth-0/3)# spanning-tree link-type point-to-point
  6. Specify the port priority to influence the selection of root or designated ports.
    device(conf-if-eth-0/3)# spanning-tree priority 64
    The range is from 0 through 240 in increments of 16. The default value is 128.
  7. Configure the path cost for spanning tree calculations on the interface.
    device(conf-if-eth-0/3)# spanning-tree cost 10000
    The lower the path cost means a greater chance that the interface becomes the root port. The range is 1 through 200000000. The default path cost is assigned as per the port speed.
  8. Configure the path cost for spanning tree calculations a specific VLAN.
    device(conf-if-eth-0/3)# spanning-tree vlan 10 cost 10000
  9. Enable root guard on the interface.
    device(conf-if-eth-0/3)# spanning-tree guard root
    Root guard protects the root bridge from malicious attacks and unintentional misconfigurations where a bridge device that is not intended to be the root bridge becomes the root bridge.
  10. Enable BPDU guard on the interface.
    device(conf-if-eth-0/3)# spanning-tree port-fast bpdu-guard
    BPDU guard removes a node that reflects BPDUs back in the network. It enforces the STP domain borders and keeps the active topology predictable by not allowing any network devices behind a BPDU guard-enabled port to participate in STP.
  11. Enable BPDU filtering on the interface.
    device(conf-if-eth-0/3)# spanning-tree port-fast bpdu-filter
    BPDU filtering allows you to avoid transmitting BPDUs on ports that are connected to an end system.
  12. Return to privileged EXEC mode.
    device(conf-if-eth-0/3)# exit
  13. Verify the configuration.
    device# show spanning-tree brief
     Spanning-tree Mode: PVST Protocol
          Root ID      Priority 4096
                       Address 768e.f805.5800
                       Hello Time 8, Max Age 25, Forward Delay 20
          Bridge ID    Priority 4096
     Interface    Role  Sts  Cost       Prio  Link-type     Edge
     Eth 0/3      DES   FWD  200000     64    P2P            No
    Observe that the settings comply with the formula set out in the STP parameters section, as:
    (2 × (forward delay - 1)) ≥ maximum age ≥ (2 × (hello time + 1))
    or in this case :38 ≥ 25 ≥ 18.
  14. Save the configuration.
PVST+ on an interface configuration example
device(conf-pvst)# interface ethernet 0/3
