ETH-CSF specifications
This section details specifications for this feature.
ETH-CSF is applicable only to point-to-point Ethernet transport applications, which means that it can work only with Down MEPs.
The following specific configuration information is required by an MEP to support ETH-CSF transmission:
The following specific configuration information is required by an MEP to support ETH-CSF reception:
An MIP is transparent to frames with ETH-CSF information and therefore does not require any information to support ETH-CSF functionality.
The ETH-CSF message indicates also the type of defect. Three CSF defect types are currently defined:
The PDU used to convey ETH-CSF information is referred to as the CSF PDU. Frames carrying the ETH-CSF indications are also referred to as CSF frames.
