Configuring a R-APS MEL value
You can configure the R-APS Maintenance Entity Group Level (MEL) value, by means of the raps-mel command. This value is carried in ERP PDUs. The default is 7.
The following example sets a nondefault R-APS MEL value.
device# configure terminal
device(config)# erp 1
device(config-erp-1)# raps-mel 6
