show cfm
Use the show cfm command to display the Connectivity Fault Management (CFM) configuration.
device# show cfm
Domain: md1
Index: 1
Level: 7
  Maintenance association: ma5
  MA Index: 5
  CCM interval: 100 ms
  Bridge-Domain ID: 50
  Priority: 7
  MAID Format: Short
  MEP   Direction  MAC              PORT       VLAN         INNER-VLAN   PORT-STATUS-TLV
  1     UP         609c.9f5f.700d   Eth 1/9    50           --           N
For the show cfm command to generate output, you must first enable CFM in protocol configuration mode.
