Displaying information related to VPLS and VLL MCT
The following examples display PW client and bridge domain information for VPLS and VLL MCT.
Displaying PW client information on an MCT cluster
The following example displays the configuration and state information of the PW client on the MCT cluster.
device# show cluster
Cluster c1
Cluster State: Active
Bringup Delay: 90 seconds
Configured Member Vlan Range: All
Active Member Vlan Range: 1
Configured Member BD Range: All
Active Member BD Range: 501
No. of Clients: 2
 Peer Info:
 Peer IP: 4.1.1.10, State: Up
 Peer Interface: Ethernet 0/4, Source IP: 4.1.1.11
 Keep-Alive:
 IP: 10.24.8.220, State: Up
 Interface: Management 0 (mgmt-vrf), Source IP: 10.24.8.221
 Client-Isolation Role: Primary
 Client Info:
 Interface               Id               Description          Local/Remote State   Exceptions
 Port-channel 10         1010                                  Up   / Up
 PW                      34816                                 Up   / Up
The following example displays only PW client and its bridge-domain information on the MCT cluster.
device# show cluster client-pw
Client Info:
Interface: PW, client-id: 34816, Deployed, State: Up
Description:
Local Vlans:
Local Bridge Domains  : 501
Remote Vlans          :
Remote Bridge Domains : 501
Number of DF Vlans    : 0
Elected DF for vlans  :
Number of DF Bridge Domains   : 1
Elected DF for Bridge Domains : 501
The following example displays the multicast and unicast labels, and forwarding state for the cluster member bridge domain.
device# show cluster member bridge-domain
BD-ID       VNI-ID              Forwarding state
  501        4597                Up
Displaying the MCT state on a bridge domain
In the show bridge-domain output, the MCT Enabled field displays whether the bridge domain is configured under a cluster configuration.
device# show bridge-domain 501
Bridge-domain 501
Bridge-domain Type: MP, VC-ID: 501
 MCT Enabled: TRUE
Description:
Number of configured end-points: 3, Number of Active end-points: 3
VE id: N/A, if-indx: N/A, Local switching: TRUE, bpdu-drop-enable: TRUE
PW-profile: default, mac-limit: 0
VLAN: 501
  Tagged ports: 1(1 up), Un-tagged ports: 0 (0 up)
  Tagged ports: po10.501
  Un-tagged ports:
VNI: 4597
  Tunnels: 1(1 up)
  Tunnels: tu32769.4597
Total VPLS peers: 1 (1 Operational):
VC id: 501, Peer address: 9.9.9.9, State: Operational, uptime: 12 min 44 sec
Load-balance: False, Cos Enabled: False,
Tunnel cnt: 1
rsvp to_a9 (cos_enable:False cos_value:0)
Assigned LSPs count:0 Assigned LSPs:
Local VC lbl: 800769, Remote VC lbl: 866325,
Local VC MTU: 1500, Remote VC MTU: 1500,
Local VC-Type: 5, Remote VC-Type: 5
Local PW preferential Status: Active, Remote PW preferential Status: Active
Local Flow Label Tx: Disabled, Local Flow Label Rx: Disabled
Remote Flow Label Tx: Disabled, Remote Flow Label Rx: Disabled
Local Control Word: Disabled, Remote Control Word: Disabled
Displaying MAC address information for a VPLS bridge domain on an MCT cluster
The following example displays the MAC address table for bridge domain of an MCT cluster.
device# show mac-address-table bridge-domain
Type Code - CCL:Cluster Client Local MAC
            CCR:Cluster Client Remote MAC
            CR:Cluster Remote MAC
VlanId/BDId   Mac-address       Type        State      Ports/LIF/PW/T
501 (B)       0000.0500.0200    Dynamic     Active     9.9.9.9
501 (B)       0000.0500.0500    Dynamic-CCL Active     Po 10.501
Total MAC addresses    :  2
The following example displays all the MAC addresses learned from other VPLS PE nodes over MCT bridge domains.
501 (B)       0000.0500.0200    CR          Active     Tu 32769 (4.1.1.11)
501 (B)       0000.0500.0500    CCR         Active     Po 10.501
