Follow this procedure to activate an LACP link even in the absence of PDUs.
Consider the following when using the
lacp default-up
command:
- The command is available only if
the configured interface is a dynamic member of a port-channel interface.
- The command is not supported on
static LAGs.
port-channel interfaces.
Enter the
configure terminal command to access global configuration mode.
Enter the
interface command, specifying the interface type and the slot/port.
device(config)# interface ethernet 0/1
Specify LACP default-up for the interface.
device(conf-if-eth-0/1)# lacp default-up
Enter the no form of the command to disable the configuration.
device(conf-if-eth-0/1)# no lacp default-up
