Shutting down PVST+ or R-PVST+
Follow these steps to o shut down PVST+, or R-PVST+ either globally, on a specific interface, or a specific VLAN.
  1. Enter global configuration mode.
    device# configure terminal
  2. Shut down PVST+ or R-PVST+.
    • Shut down PVST+ or R-PVST+ globally and return to privileged EXEC mode.
      device(config)# protocol spanning-tree pvst
      device(config-pvst)# shutdown
      device(config-pvst)# end
    • Shut down PVST+ or R-PVST+ on a specific interface and return to privileged EXEC mode.
      device(config)# interface ethernet 0/2
      device(conf-if-eth-0/2)# spanning-tree shutdown
      device(conf-if-eth-0/2)# end
    • Shut down PVST+ or R-PVST+ on a specific VLAN. and return to privileged EXEC mode.
      device(config)# vlan 10
      device(config-vlan-10)# spanning-tree shutdown
      device(config-vlan-10)# end
  3. Verify the configuration.
    device# show spanning-tree
    device#
  4. Save the running configuration to the startup configuration.
Shut down PVST+ or R-PVST+ configuration example
Shutting down PVST+ on a VLAN is used in this example.
