LVTEP support for other features
This section details how LVTEP supports other features.
AC LIF
AC LIFs of type untagged, single tagged, and double tagged are supported.
Layer 2 ACLs
Layer 2 end points (leaf) support Layer 2 ACLs.
Rate limiting
Layer 2 end points (leaf) do not support rate limiting.
QoS
QoS behavior is similar to that for a single VTEP gateway. Details are listed in the following tables for DiffServe tunneling uniform and pipe modes in an overlay network.
Table 1. QoS behavior for DiffServ tunneling uniform mode
Traffic type
VXLAN origination
VXLAN tunnel termination
VLAN cases (untagged)
DSCP 0 and TTL 255 are sent on the tunnel header.
NA
VLAN cases (tagged)
Priority Code Point (PCP) is mapped to IP DCSP of VXLAN tunnel and TTL is set to 255.
DSCP is remapped to PCP of L2 traffic.
BD (raw, single tagged)
PCP of VLAN is mapped to DSCP and TTL is set to 255.
DCSP is remapped to PCP of VLAN.
BD (raw, double tagged)
PCP of outer VLAN is mapped to DSCP and TTL is set to 255.
DCSP is remapped to PCP of both inner and outer VLAN. Original PCP inner VLAN is not retained.
BD (raw, untagged)
NA
BD (tagged, single tagged)
PCP is mapped to DSCP and TTL is set to 255
BD (tagged, double tagged)
Outer VLAN PCP is mapped to DSCP and TTL is 255 Inner VLAN header is carried with original PCP.
DSCP is remapped to PCP of outer VLAN and Inner VLAN of L2 traffic.
BD (tagged, untagged)
DSCP 0 and TTL 255 are sent on the tunnel header. Dummy VLAN is added: VLAN ID is BD ID and PCP is 0.
NA
Table 2. QoS behavior for DiffServ tunneling pipe mode
Traffic type
VXLAN origination
NA
VLAN cases (tagged)
PCP value is set to 0 as inner VLAN is not carried.
PCP value is set to 0 as inner VLAN is not carried. PCP is cleared for both tags.
BD (raw, untagged)
NA
DSCP 0 and TTL 255 are sent on the tunnel header. VLAN is carried and PCP is carried.
PCP value is set to zero.
DSCP 0 and TTL 255 are sent on the tunnel header. Inner VLAN is carried and PCP is carried.
NA
MTU
MTU behavior is similar to that for a single VTEP gateway.
Inner packet tag behavior
Inner packet tag behavior is similar to that for a single VTEP gateway.
The following table summarizes this behavior for VLANs and BDs.
Table 3. Inner packet tag behavior for VLANs and BDs
VLAN/BD Configuration Inner packet tag behavior Remarks
Inner packet is always untagged.
BD raw mode
This is RFC-compliant behavior.
BD tagged mode
Inner packet is always tagged.
This mode can be used if a tag must always be sent in the inner packet.
Statistics
The LVTEP tunnel CCEP supports statistics. For BUM traffic, although the traffic is suppressed (through split horizon), it is still accounted for as part of the statistics. This behavior is the same as existing single VTEP behavior.
