LVTEP show commands
The following show commands are helpful in diagnosing a variety of LVTEP configurations.
Cluster show commands
show cluster
device# show cluster
Cluster default
Cluster State: Active/Shutdown
Bringup Delay: 10 seconds
Configured Member Vlan Range: All
Active Member Vlan Range: 1-352,456-765,783,785-795
Configured Member BD Range: All
Active Member BD Range: 3-5,26-42
No. of Clients: 4
 Peer Info:
 Peer IP: 10.1.1.26, State: Up
 Peer Interface: Ethernet 0/41, Source IP: 10.1.1.28
 Keep-Alive:
 IP: 24.1.1.26, State: Down (Source-interface Down)
 Interface: Ethernet 0/20 (default-vrf), Source IP: 22.1.1.28
 Interval: 100ms
 Role: Secondary
 Client Info:
 Interface         Id             Description	  Local/Remote State       Exceptions
 Ethernet 0/11     11             Spirent 3/3         Up   / Down              Remote Down
 Port-channel 20   1020           Server_U27          Up   / Up
 Tunnel 32771      30.30.30.30                        Up   / Up                VLAN mismatch
 PW                34816                              Down / Down              Client Down
show cluster client
device# show cluster client 22
Client Info:
Interface: Port-channel 20, client-id: 1020, Deployed, State: Up
Description		  : U27
Local Vlans		  : 1,61-300
Local Bridge Domains	: 20,100
Remote Vlans		 : 1,61-300
Remote Bridge Domains      : 20
DF Elected for all vlans/BDs
BGP show commands
show bgp evpn routes type inclusive-multicast detail
device# show bgp evpn routes type inclusive-multicast detail
Total number of BGP EVPN IMR Routes : 12
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
       E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH
       S:SUPPRESSED F:FILTERED s:STALE
Route Distinguisher: 6.6.100.6:32779
1       Prefix: IMR:[0][IPv4:6.6.100.6],  Status: BL,  Age: 1h54m39s
         NEXT_HOP: 0.0.0.0, Learned from Peer: Local Router
          LOCAL_PREF: 100,  MED: 0,  ORIGIN: incomplete,  Weight: 0
         AS_PATH:
            Extended Community: RT 100:1073741835
            Adj_RIB_out count: 2,  Admin distance 0
            L2 Label: 11
            RD: 6.6.100.6:32779
Route Distinguisher: 7.7.100.7:32779
5       Prefix: IMR:[0][IPv4:7.7.100.7],  Status: BI,  Age: 1h53m37s
         NEXT_HOP: 7.7.100.7, Metric: 1, Learned from Peer: 7.7.100.7 (100)
         AS_PATH:
            Extended Community: RT 100:1073741835 RT 100:268435456 RT 100:0 ExtCom:03:0c:00:00:00:00:0a:00
            PMSI Attribute Flags: 0x00000000  Label-Stack: 817163 Tunnel-Type: 6 Tunnel-IP: 0.0.0.0
            Extended Community: ExtCom: Tunnel Encapsulation (Type MPLS)
            L2 Label: 817163
            RD: 7.7.100.7:32779
Route Distinguisher: 8.8.100.8:32779
9       Prefix: IMR:[0][IPv4:8.8.100.8],  Status: BI,  Age: 1h53m29s
         NEXT_HOP: 8.8.100.8, Learned from Peer: 8.8.100.8 (100)
         AS_PATH:
            Extended Community: RT 100:1073741835 RT 100:268435467 RT 100:11 ExtCom:03:0c:00:00:00:00:08:00
            PMSI Attribute Flags: 0x00000000  Label-Stack: 11 Tunnel-Type: 6 Tunnel-IP: 8.8.100.8
            Extended Community: ExtCom: Tunnel Encapsulation (Type Vxlan)
            L2 Label: 11
            RD: 8.8.100.8:32779
show bgp evpn routes type mac detail
device# show bgp evpn routes type mac detail
Total number of BGP EVPN MAC Routes : 2
Route Distinguisher: 6.6.100.6:36865
1       Prefix: MAC:[0][0000.0607.0000],  Status: BL,  Age: 0h0m53s
         AS_PATH:
            Extended Community: RT 100:1073745921
            L2 Label: 4097
            ESI : 00.000000000000000000
            RD: 6.6.100.6:36865
2       Prefix: MAC:[0][0000.0807.0000],  Status: BI,  Age: 0h5m16s
         AS_PATH:
            L2 Label: 11
            RD: 8.8.100.8:32779
Tunnel show commands
show tunnel brief
device# show tunnel brief
Tunnel 32771, mode VXLAN, unicast
Admin state up, Oper state up
Source IP 6.7.100.67 (  Loopback 2 ), Vrf default-vrf
Destination IP 8.8.100.8
show tunnel
device# show tunnel 32771
Ifindex 0x7c00f001, Admin state up, Oper state up
Overlay gateway "gw1", ID 1
Configuration source BGP-EVPN
MAC learning BGP-EVPN
Tunnel QOS mode UNIFORM
Active next hops on node 1:
    IP: 10.6.8.8, Vrf: default-vrf
    Egress L3 port: Ve 3, Outer SMAC: 609c.9f5a.3d15
    Outer DMAC: 609c.9f5a.4515, ctag: 0
    BUM forwarder: yes
Packet count: RX 167993610       TX 995395
Byte count  : RX 29902862580     TX 226950060
