MAC movement Detection and Resolution Commands
The following commands support MAC movement detection and resolution.
Table 1. MAC movement detection and resolution commands
Command
Details
mac-address-table mac-move detect
Enables MAC movement detection. Disabled by default. Once enabled, use the no form to disable.
mac-address-table mac-move limit
Defines the movement threshold. Enter a value; default is 20, range is 3 through 500.
mac-address-table mac-move action
Define the action to be taken when MAC movement exceeds the specified threshold. Default action is RASlog. Enabled by default when mac-address-table mac-move detect is enabled.
mac-address-table mac-move auto-recovery enable
Enables auto-recovery on the port/interface after a shutdown action. Enabled by default when shutdown is enabled.
mac-address-table mac-move auto-recovery time
Sets the auto recovery time. Default auto-reovery time is 5 minutes. Range is 3 through 30 minutes.
clear mac-address-table mac-move shut-list
Clears all entries from the shutdown list.
show bridge-domain [bd-id] logical-interface
LIF output has been modified to indicate when the LIF is down due to mac-movement.
show mac-address-table mac-move shut list
Displays information for all entries in the shutdown list.
Displays all mac-move configurations.
show vlan
Output has been modified to indicate when the LIF/port is down due to mac-movement.
show vlan detail
show vlan interface port-channel
Output has been modified to indicate when the VLAN is down due to mac-movement.
