Re-enabling an error-disabled port automatically
Enable a port to automatically recover from the error-disabled state after the expiration of an error recovery timer.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter STP configuration mode.
    device(config)# protocol spanning-tree stp
  3. Enable the error-disable-timeout timer.
    device(config-stp)# error-disable-timeout enable
  4. Set an interval after which port shall be enabled.
    device(config-stp)# error-disable-timeout interval 60
    The interval range is from 0 to 1000000 seconds, the default is 300 seconds.
  5. Return to privileged EXEC mode.
    device(config-stp)# end
  6. Verify the configuration.
    device# show spanning-tree
     Spanning-tree Mode: Spanning Tree Protocol
     Root Id: 8000.768e.f805.5800 (self)
     Bridge Id: 8000.768e.f805.5800
     Root Bridge Forward Delay: 15; Hello Time: 2; Max Age: 20; Max-hops: 20
     Configured Forward Delay: 15; Hello Time: 2; Max Age: 20; Max-hops: 20
     Number of topology change(s): 0
     Bpdu-guard errdisable timeout: enabled
     Bpdu-guard errdisable timeout interval: 60 sec
Automatically re-enable an error-disabled port configuration example
