DHCP Deployment Considerations
Before defining an DHCP server configuration, refer to the following deployment guidelines to ensure the configuration is optimally effective:
- DHCP option 189 is required when AP650
model access points are deployed over a layer 3 network and require layer 3 adoption.
DHCP services are not required for AP650
access points connected to a VLAN that's local to the controller or service
platform.
- DHCP's lack of an authentication mechanism means a DHCP server
cannot check if a client or user is authorized to use a given user class. This
introduces a vulnerability when using user class options. For example, if a user
class is used to assign a special parameter (for example, a database server), there
is no way to authenticate a client and it's impossible to check if a client is
authorized to use this parameter.
- Ensure that traffic can pass on UDP ports 67 and 68 for clients
receiving DHCP information.
