Refer to the advanced profile‘s Antenna menu to set or override the AP510e access point profile‘s antenna configuration. The ExtremeMobility AP510e is a dual-radio access point, with eight, external Wi-Fi antennas grouped into: group-1 (consisting of antenna ports 1 to 4) and group-2 (consisting of antenna ports 5 to 8).
To enable the AP510e radios, you need to map a WLAN to the AP radio and configure the antenna-id for the 'group-1' and 'group-2' antenna ports. The antenna-id configuration depends on the software mode applied on the AP510e access point radios.
The following table lists the external antenna configurations required for the three different software modes supported on the AP510e model access point:
AP510e: External Antenna Configurations
| Antenna Ports | ||
| Software Mode | 2.4/5G Antennas: 1, 2, 3, 4 | 5G Antennas: 5, 6, 7, 8 |
Mode 1
Note: This mode requires only FOUR, dual-band antennas connected to ANT
sockets 1 to 4.
Dual-band 2.4 GHz/5 GHz | None |
Mode 2
Note: This mode requires FOUR, dual-band antennas connected to ANT
sockets 1 to 4, and FOUR, 5G-band antennas connected to ANT
sockets 5 to 8.
Dual-band 2.4 GHz/5 GHz | 5 GHz |
Mode 3
Note: Requires FOUR, 5G-band antennas connected to ANT
sockets 5 to 8.
5 GHz | 5 GHz |
To configure the antenna-id for AP510e profile:
A list of default and user-created profiles is displayed.
The selected profile's configuration menu is displayed.
| Antenna ID Group 1 Option | Use this drop-down menu to configure
the antenna-id (type of antenna) used in
the antenna ports 1 to 4 (group-1
antennas). Traffic for all three software modes is routed through antenna ports 1 to 4. Note: Refer to the
table above for the
supported software modes and the
corresponding antenna configurations
required.
| Antenna ID Group 2 Option | Use this drop-down menu to configure
the antenna-id used in the antenna ports
5 to 8 (group-2 antennas). The antenna types supported for 'group-1' and 'group-2' antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pna7-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-dq05120, and Default. The default setting is 'Default'. Group-2 antenna configuration is ONLY required for software modes 2 & 3. Note: Refer to the table above for the supported
software modes and the corresponding
required.
