Adding and Editing Network Group Alias
You can add a new network group alias configuration or edit an existing configuration.
  1. Select Add to create a new alias, Edit to modify the attributes of an existing alias, or Delete to remove obsolete aliases.
    Use Copy to create a copy of the selected policy and modify it for further use. Use Rename to rename the selected policy.
    Network Group Alias - Add/Edit Screen
  2. If you are adding a new network alias rule, provide a name up to 32 characters. The network group alias name always starts with a dollar sign ($).
  3. Define the following network group alias parameters:
    Host
    Specify the Host IP address for up to eight IP addresses supporting network aliasing. Select the down arrow to add the IP address to the table.
    Network
    Specify the netmask for up to eight IP addresses supporting network aliasing. Subnets can improve network security and performance by organizing hosts into logical groups. Applying the subnet mask to an IP address separates the address into a host address and an extended network address. Select the down arrow to add the mask to the table.
  4. Select + Add Row, in the Range table to specify the Start IP address and End IP address for the alias range, or double-click on an existing alias range entry to edit it.
  5. Select OK when completed to update the network group alias settings.
    Select Reset to revert the screen to its last saved configuration.p
