Network Group Alias
A network group alias is a set of configurations consisting of host and network configurations. Network configurations are complete networks in the form of 192.168.10.0/24 or an IP address range in the form of 192.168.10.10-192.168.10.20. Host configurations are in the form of a single IP address, 192.168.10.23.
A network group alias can contain multiple definitions for a host, network, and IP address range. A maximum of eight (8) host entries, eight (8) network entries and eight (8) IP addresses range entries can be configured inside a network group alias. A maximum of 32 network group alias entries can be created.
A network group alias can be used in IP firewall rules to substitute hosts, subnets and IP address ranges.
To edit or delete a network alias configuration:
  1. Select the Network Group Alias tab.
    Network Alias - Network Group Alias Screen
  2. Review the following to determine if a new alias configuration is needed or an existing configuration warrants modification:
    Name Displays the administrator assigned name associated with the network group alias.
    Host Displays all the host aliases in the listed network group alias. Displays a blank column if no host alias is defined.
    Network Displays all network aliases in the listed network group alias. Displays a blank column if no network alias is defined.
