Event History
The Event History screen displays events for both wireless controllers and access points. The Controller(s) tab displays by default. Information on this tab can be filtered by controllers and then further by the RF Domains on the selected controller. Similarly, the access point(s) tab displays information for each RF Domain on the access point and this information can be further filtered on the devices adopted by this access point.
To review the Event History:
  1. Select Diagnostics > Fault Management > Event History
    Fault Management - Event History screen
  2. In the Controller(s) tab, select the controller from the Select a Controller field to filter events to display. To filter messages further, select a RF Domain from the Filter by RF Domain field.
  3. In the access point(s) tab, select the RF Domain from the Select a RF Domain field to filter events to display. To filter messages further, select a device from the Filter by Device field.
  4. Select Fetch Historical Events from the lower, right-hand, side of the UI to populate the table with either device or RF Domain events. The following event data is fetched and displayed:
    Timestamp
    Displays the timestamp (time zone specific) each listed event occurred.
    Module
    Displays the module tracking the listed event. Events detected by other modules are not tracked.
    Message
    Displays error or status messages for each event.
    Severity
    Displays the severity of the event as defined for tracking from the Configuration screen. Severity options include:
    All Severities – All events are displayed irrespective of their severity
    Critical – Only critical events are displayed
    Error – Only errors and above are displayed
    Warning – Only warnings and above are displayed
    Informational – Only informational and above events are displayed
    Source
    Displays the MAC address of the device tracked by the selected module.
    Hostname
    Displays the Hostname/IP address of the device tracked by the selected module.
    RF Domain
    Displays the RF Domain where the selected access point MAC address resides.
  5. Select Clear All to clear events and begin new event data gathering.
