AP Critical Resources
The Critical Resources screen displays device IP addresses on the network (gateways, routers etc.). These IP addresses are critical to the health of the access point managed network. Critical resources are pinged regularly by the access point. If there's a connectivity issue, an event is generated stating a critical resource is unavailable. Each device's VLAN, ping mode and state is displayed for the administrator.
To review a selected access point's critical resource statistics:
  1. Select the Statistics menu from the Web UI.
  2. Expand the System node from the navigation pane (on the left-hand side of the screen). The System node expands to display the RF Domains created within the managed network.
  3. Expand an RF Domain node, and select one of it's connected access points. The access point's statistics menu displays in the right-hand side of the screen, with the Health tab selected by default.
  4. Select Critical Resource from the left-hand side of the UI.
    The Statistics > AP > Critical Resource screen is displayed in the right-hand pane.
    Refer to the General field to assess the Monitor Interval and Monitor Using Flows Interval used to poll for updates from the critical resource IP listed for Source IP For Port Limited Monitoring. Monitoring Retries before Marking resource as DOWN are the number of retry connection attempts permitted before this listed resource is defined as down (offline).
    Refer to the following List of Critical Resources stats:
    Critical Resource Name Lists the name of the critical resource monitored by the access point. Critical resources are device IP addresses on the network (gateways, routers etc.). These IP addresses are critical to the health of the network. These device addresses are pinged regularly by access points. If there‘s a connectivity issue, an event is generated stating a critical resource is unavailable.
    Via Lists the VLAN used by the critical resource as a virtual interface. the VLAN displays as a link than can be selected to list configuration and network address information in greater detail.
    Status Defines the operational state of each listed critical resource VLAN interface (Up or Down).
    Error Reason Provides an error status as to why the critical resource is not available over its designated VLAN.
    Mode Defines the operational state of each listed critical resource (up or down).
  5. Select Refresh to update the statistics counters to their latest values.
