Accounting is the method of collecting and sending security server information for billing, auditing, and reporting user data; such as start and stop times, executed commands (such as PPP), number of packets and number of bytes. Accounting enables wireless network administrators to track the services users are accessing and the network resources they are consuming. When accounting is enabled, the network access server reports and logs user activity to a RADIUS security server in the form of accounting records. Each accounting record is stored on a local access control server. The data can be analyzed for network management, client billing, and/or auditing. Accounting methods must be defined through AAA.
Accounting can be enabled and applied to WLANs, to uniquely log accounting events specific to the WLAN. Accounting logs contain information about the use of remote access services by users. This information is of great assistance in partitioning local versus remote users and how to best accommodate each. Remote user information can be archived to an external location for periodic network and user permission administration.
To configure WLAN accounting settings:
Enable Syslog Accounting | Use this option to generate accounting records in standard syslog format (RFC 3164). The feature is disabled by default. |
Syslog Host |
Use the drop-down menu to select either Hostname
or IP Address. Based on th eoption you
have selected, specify the IP address or hostname of the external
syslog host where accounting records are routed.
Note:
Hostnames cannot include an underscore character. |
Syslog Port | Use the spinner control to set the destination UDP port number of the external syslog host where the accounting records are routed. The default port is 514. |
Proxy Mode | If a proxy is needed to connect to the syslog server, choose a proxy mode of Through RF Domain Manager or Through Wireless Controller. If no proxy is needed, select None. |
Format | Specify the delimiter format for the MAC address to be packed in the syslog request. Available formats are No Delimiter (aabbccddeeff), Colon Delimiter (aa:bb:cc:dd:ee:ff), Dash Delimiter (aa-bb-cc-dd-ee-ff), Dot Delimiter (aabb.ccdd.eeff) and Middle Dash Delimiter (aabbcc-ddeeff). |
Case | Specify to send the MAC addresses in either Uppercase or Lowercase for syslog requests. The default setting is Uppercase. |
