Authorized access points and clients are generally known to you and conform with your organization‘s security policies. Unauthorized devices are those detected as interoperating within the network, but have not been approved. These devices should be filtered to avoid jeopardizing the data managed by the access point and its connected clients. Use the Device Categorization screen to apply neighboring and sanctioned (approved) filters on peer access points operating in this access point‘s radio coverage area. Detected client MAC addresses can also be filtered based on their classification in this access point‘s coverage area.
To categorize access points and clients as authorized or unauthorized:
Index | Use the spinner control to designate a index value to this entry. Use a value in the range 1 - 1000. |
Classification | Use the drop-down menu to designate the target device as either Sanctioned or Neighboring. |
Device Type | Use the drop-down menu to designate the target device as either an access point or client. |
MAC Address | Enter the factory coded MAC address of the target device. This address is hard coded by the device manufacturer and cannot be modified. This MAC address is defined as authorized or unauthorized as part of the device categorization process. |
SSID | Enter the SSID of the target device requiring categorization. The SSID cannot exceed 32 characters. |
