Use the Path Method Root Path Metric screen to set a profile's mesh point root path scan settings.
To define the path method root path metric:
| Channel Width | Set the channel width the mesh point's automatic channel scan
assigns to the selected radio. Available options include:
| Priority Meshpoint | Configure the mesh point monitored for automatic channel scans. This is the mesh point assigned priority over other available mesh points. When configured, a mesh connection is established with this mesh point. If not configured, a mesh point is automatically selected. This setting is disabled by default. |
| Meshpoint: Path Minimum | Set the minimum path metric (from 100 - 20,000) for mesh connection establishment. The default setting is 1000. |
| Meshpoint: Path Metric Threshold | Configure a minimum threshold (from 800 - 65535) for triggering an automatic channel selection for mesh point selection. The default is 1500. |
| Meshpoint: Tolerance Period | Configure a duration to wait before triggering an automatic channel selection for the next mesh hop. The default is one minute. |
| Meshpoint Root: Sample Count | Set the number of scans (from 1- 10) for data collection before a mesh point root is selected. The default setting is 5. |
| Meshpoint Root: Off-channel Duration | Define the duration (from 20 - 250 milliseconds) for scan dwells on each channel, when performing an off channel scan. The default setting is 50 milliseconds. |
| Meshpoint Root: Channel Switch Delta | Configure the delta (from 5 - 35 dBm) that triggers a mesh point root automatic channel selection when exceeded. The default setting is 10 dBm. |
| Meshpoint Root Off-channel Scan Frequency | Configure the duration (from 1 -60 seconds) between two consecutive off channel scans for mesh point root. The default is 6 seconds. |
| Meshpoint Root Channel Hold Time | Set the minimum duration (from 0 - 1440 minutes) to remain on a selected channel before channel conditions are reassessed for a possible channel change. Set this value to zero (0) to prevent an automatic channel selection from occurring. The default is 30 minutes. |
