To view T5 controller connected CPE fe port utilization:
Name | Displays the name of the selected CPE fe Ethernet port. |
Rx (Kpbs) | Displays the listed CPE fe Ethernet port receive data rate (in Kbps). |
RX (p/s) | Lists a packet per second Ethernet port receive rate. |
Rx Utilization (%) | Lists each port's receive direction utilization as a percentage of available receive bandwidth available. |
Tx (Kbps) | Displays the listed CPE ge Ethernet port transmit data rate (in Kbps). |
Tx (p/s) | Lists a packet per second fe Ethernet port transmit rate. |
Tx Utilization (%) | Lists each fe port's transmit direction utilization as a percentage of available transmit bandwidth available. |
