ISIS.Export.WalkRtTypeAllocFail
Description
ISIS could not initiate a route walk for the specified protocol. As a result, export of the specified protocol may not work properly.
Remedy
This is a symptom of low system memory resources. A less complex or scaled configuration may be necessary in order to enable exporting of the specified protocol. Reduce the configuration to free up resources, then disable and re-enable exporting of this protocol.
Severity
Error
Message Text
failed to allocate route walk structure for route type %proto%
Message Parameters
Name Type
proto String
