The MAC-based VLAN entries can be configured here. This page allows for adding and deleting MAC-based VLAN entries and assigning the entries to different ports. This page shows only static entries.
Object | Description |
Delete | To delete a MAC-based VLAN entry, check this box and click save. The entry will be deleted in the stack. |
MAC Address | Indicates the MAC address. |
VLAN ID | Indicates the VLAN ID. |
Port Members | A row of check boxes for each port is displayed for each MAC-based VLAN entry. To include a port in a MAC-based VLAN, check the box. To remove or exclude the port from the MAC-based VLAN, make sure the box is unchecked. By default, no ports are members, and all boxes are unchecked. |
Adding a New MAC-based VLAN | Click Add New Entry to add a new MAC-based VLAN entry. An empty row is added to the table, and the MAC-based VLAN entry can be configured as needed. Any unicast MAC address can be configured for the MAC-based VLAN entry. No broadcast or multicast MAC addresses are allowed. Valid VLAN ID values are 1 – 4095. The MAC-based VLAN entry is enabled when you click on Save. A MAC-based VLAN without any port members will be deleted when you click Save. The Delete button can be used to undo the addition of new MAC-based VLANs. The maximum possible MAC-based VLAN entries are limited to 256. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
