DHCP Snooping
Configure DHCP Snooping on this page.
Object Description
Snooping Mode Indicates the DHCP snooping mode operation. Possible modes are:
  • Enabled: Enable DHCP snooping mode operation. When DHCP snooping mode operation is enabled, the DHCP request messages will be forwarded to trusted ports and only allow reply packets from trusted ports.
  • Disabled: Disable DHCP snooping mode operation.
Port Mode Configuration Indicates the DHCP snooping port mode. Possible port modes are:
  • Trusted: Configures the port as trusted source of the DHCP messages.
  • Untrusted: Configures the port as untrusted source of the DHCP messages.
Buttons
Save changes.
Undo any changes and revert to previously saved values.
