This page configures global mode and VLAN mode to enable/disable DHCP server per system and per VLAN.
Object | Description |
Global Mode | |
Mode | Configure the operation mode per system. Possible modes are:
VLAN Mode | |
VLAN Range | Indicate the VLAN range in which DHCP server is enabled or disabled. The first VLAN ID must be smaller than or equal to the second VLAN ID. However, if the VLAN range contains only one VLAN ID, then you can just input it into either one of the first and second VLAN ID, or both. If you want to disable the existing VLAN range, follow these steps:
Mode | Indicate the operation mode per VLAN. Possible modes are:
Buttons | |
Undo the addition of the new entry or server. |
Add a new VLAN range. |
Save changes. |
Undo any changes and revert to previously saved values. |
