MSTI Priorities
This page allows you to inspect the current STP MSTI bridge instance priority configurations, and possibly change them as well.
Object Description
MSTI The bridge instance. The CIST is the default instance, which is always active.
Priorities Controls the bridge priority. Lower numeric values have better priority. The bridge priority plus the MSTI instance number, concatenated with the 6-byte MAC address of the switch forms a Bridge Identifier.
Buttons
Save changes.
Undo any changes and revert to previously saved values.
