Aging Configuration |
Disable Automatic Aging |
Disable the automatic aging of dynamic entries by ticking the item. |
Aging Time |
Enter a value in seconds. Valid values are 10 – 1000000 seconds. |
MAC Table Learning |
Auto |
Learning is done automatically as soon as a frame with unknown SMAC is received. |
Disable |
No learning is done. |
Secure |
Only static MAC entries are learned, all other frames are dropped.
Note: Make sure that the link used for managing the switch is added to the Static Mac Table before changing to secure learning mode, otherwise the management link is lost and can only be restored by using another non-secure port or by connecting to the switch via the serial interface. |
Static MAC Table Learning |
Delete |
Check to delete the entry. It will be deleted during the next save. |
VLAN ID |
The VLAN ID of the entry. |
MAC Address |
The MAC address of the entry. |
Port Members |
Checkmarks indicate which ports are members of the entry. Check or uncheck as needed to modify the entry. |
