SNMP Views
Configure SNMPv3 view table on this page. The entry index keys are View Name and OID Subtree.
Object Description
Delete Check to delete the entry. It will be deleted during the next save.
View Name A string identifying the view name that this entry should belong to. The allowed string length is 1 to 32, and the allowed content is ASCII characters from 33 to 126.
View Type Indicates the view type that this entry should belong to. Possible view types are:
  • included: An optional flag to indicate that this view subtree should be included.
  • excluded: An optional flag to indicate that this view subtree should be excluded.
    In general, if a view entry's view type is 'excluded', there should be another view entry existing with view type as 'included' and it's OID subtree should overstep the 'excluded' view entry.
OID Subtree The OID defining the root of the subtree to add to the named view. The allowed OID length is 1 to 128. The allowed string content is digital number or asterisk(*).
Buttons
Add a new entry.
Save changes.
Undo any changes and revert to previously saved values.
