Alarm Profile is provided here to enable/disable alarm.
When any alarm exists, the Alarm LED will be on (lighted), and the Alarm Output Relay will also be enabled.Object | Description |
ID | The identification of the Alarm Profile entry. |
Description | Alarm Type description. |
Enabled | If alarm entry is Enabled, then alarm will be shown in alarm history/current when it occurs. Alarm LED will be on (lighted), Alarm Relay also be enabled. SNMP trap will be sent if any SNMP trap entry exists and enabled. |
Disabled | If alarm entry is Disabled, alarm will not be captured/shown in alarm history/current when alarm occurs. It will not trigger the Alarm LED change, Alarm Relay, and SNMP trap either. |
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
