This page shows the QCL status by different QCL users. Each row describes the QCE that is defined. It is a conflict if a specific QCE is not applied to the hardware due to hardware limitations. The maximum number of QCEs is 256 on each switch.
Object | Description |
User | Indicates the QCL user. |
QCE | Indicates the QCE id. |
Port | Indicates the list of ports configured with the QCE. |
Frame Type | Indicates the type of frame. Possible values are:
Action | Indicates the classification action taken on ingress
frame if parameters configured are matched with the frame's content. Possible actions are:
Conflict | Displays Conflict status of QCL entries. As H/W
resources are shared by multiple applications. It may happen that resources
required to add a QCE may not be available, in that case it shows conflict
status as 'Yes'; otherwise, it is always 'No'. Note: Conflict can
be resolved by releasing the H/W resources required to add QCL entry
using the Resolve Conflict
button.
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page. |
Select the QCL status from the drop-down menu. |
Release the resources required to add QCL entry, in case the conflict status for any QCL entry is 'yes'. |
