History Index |
Indicates the index of History control entry. |
Sample Index |
Indicates the index of the data entry associated with the control entry. |
Sample Start |
The value of sysUpTime at the start of the interval over which this sample was measured. |
Drop |
The total number of events in which packets were dropped by the probe due to lack of resources. |
Octets |
The total number of octets of data (including those in bad packets) received on the network. |
Pkts |
The total number of packets (including bad packets, broadcast packets, and multicast packets) received. |
Broadcast |
The total number of good packets received that were directed to the broadcast address. |
Multicast |
The total number of good packets received that were directed to a multicast address. |
CRCErrors |
The total number of packets received that had a length (excluding framing bits, but including FCS octets) of between 64 and 1518 octets, inclusive, but had either a bad Frame Check Sequence (FCS) with an integral number of octets (FCS Error) or a bad FCS with a non-integral number of octets (Alignment Error). |
Undersize |
The total number of packets received that were less than 64 octets. |
Oversize |
The total number of packets received that were longer than 1518 octets. |
Frag. |
The number of frames which size is less than 64 octets received with invalid CRC. |
Jabb. |
The number of frames which size is larger than 64 octets received with invalid CRC. |
Coll. |
The best estimate of the total number of collisions on this Ethernet segment. |
Utilization |
The best estimate of the mean physical layer network utilization on this interface during this sampling interval, in hundredths of a percent. |
