Local Port |
The port on which the LLDP frame was received. |
Chassis ID |
The Chassis ID is the identification of the neighbor's LLDP frames. |
Port ID |
The Port ID is the identification of the neighbor port. |
Port Description |
Port Description is the port description advertised by the neighbor unit. |
System Name |
System Name is the name advertised by the neighbor unit. |
System Capabilities |
System Capabilities describes the neighbor unit's capabilities. The possible capabilities are:
- Other
- Repeater
- Bridge
- WLAN Access Point
- Router
- Telephone
- DOCSIS cable device
- Station only
- Reserved
When a capability is enabled, the capability is followed by (+). If the capability is disabled, the capability is followed by (-).
Management Address |
Management Address is the neighbor unit's address that is used for higher layer entities to assist discovery by the network management. This could for instance hold the neighbor's IP address. |
