This page provides ARP Inspection related configuration.
Object | Description |
Mode of ARP Inspection Configuration | Enable the Global ARP Inspection or disable the Global ARP Inspection. |
Port Mode Configuration |
Specify ARP Inspection is enabled on which ports. Only when both Global
Mode and Port Mode on a given port are enabled, ARP Inspection is enabled
on this given port. Possible modes are:
If you
want to inspect the VLAN configuration, you
have to enable the setting of Check
VLAN. The default setting of Check VLAN is disabled.
When the setting of “Check VLAN” is disabled, the log type of ARP
Inspection will refer to the port setting. And the setting of “Check
VLAN” is enabled, the log type of ARP Inspection will refer to the VLAN
setting. Possible setting of “Check VLAN” are:
Only
the Global Mode and Port Mode on a given port are enabled, and the
setting of Check VLAN is disabled,
the log type of ARP Inspection will refer to the port setting. There are
four log types and possible types are:
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
Translate all dynamic entries into static entries. |
