Configure port mirroring on this page. To debug network problems, selected traffic can be copied, or mirrored, on a mirror port where a frame analyzer can be attached to analyze the frame flow.
Object | Description |
Port to mirror | Port to mirror also known as the mirror port. Frames from ports that have either source (rx) or destination (tx) mirroring enabled are mirrored on this port. Disabled disables mirroring. |
Port | The logical port for the settings contained in the same row. |
Mode | Select a mirror mode:
Note: For a given port, a frame is only transmitted once.
It is therefore not possible to mirror mirror port Tx frames. Because of
this, mode for the selected mirror port is limited to Disabled or Rx
only.
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
