Initial Switch Configuration
Before configuring ERPS through the web interface, configure your switches as follows. In this example, there are three switches getting configured.
  1. Because all switches have the same IP initially, it is best to connect to the switch locally and then configure its IP.
  2. While you are in the CLI:
    1. Disable Spanning Tree by entering no spanning-tree.
      Spanning Tree is enabled by default. Disabling it ensures STP does not conflict with ERPS.
      You must be in Configuration Mode to run this command (see "Execution Modes" in the ISW Series Managed Industrial Ethernet Switch Command Reference Guide).
    2. Disable Loop Protection by entering no loop-protect.
  3. Connect switch 1 to switch 2, and switch 1 to switch 3.
    Caution
    Caution
    Do not connect switch 2 to switch 3, or you will create a loop.
  4. Access switch 1 by entering the IP address into a web browser (see Browser Support).
  5. Enable VLAN tag aware. To do this:
    1. Navigate to Configuration > VLANs.
    2. Configure the ports as follows:
      Port Mode Port Type
      1 Hybrid C-Port
      2 Hybrid C-Port
    3. Click Save button.
    4. Repeat for the remaining switches.
    Configuring VLAN Tag Aware on Ports 1 and 2
    Port VLAN Configuration table. Drop-down lists are used to select configuration values for 8 ports
