Each page shows up to 99 entries from the IGMP Group table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the IGMP Group Table.
The Start from VLAN and Group input fields allow you to select the starting point in the IGMP Group Table. Clicking the Refresh button will update the displayed table starting from that or the closest next IGMP Group Table match. In addition, the two input fields will, upon a Refresh button click, assume the value of the first displayed entry, allowing for continuous refresh with the same start address.
The will use the last entry of the
currently displayed table as a basis for the next lookup. When the end is reached,
No more entries shows in the displayed table. Use the
button to start over.
Object | Description |
VLAN ID | VLAN ID of the group. |
Groups | Group address of the group displayed. |
Port Members | Ports under this group. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
