Click Start to run the diagnostics. This will take approximately five seconds. If all ports are selected, this can take approximately 15 seconds. When completed, the page refreshes automatically, and you can view the cable diagnostics results in the cable status table. Note that VeriPHY is only accurate for cables of length 7 – 140 meters.
10 and 100 Mbps ports will be linked down while running VeriPHY. Therefore, running VeriPHY on a 10 or 100 Mbps management port will cause the switch to stop responding until VeriPHY is complete.
Object | Description |
Port | The port where you are requesting VeriPHY Cable Diagnostics. |
Cable Status |
Buttons | |
Start transmitting ICMP packets. |
Re-start diagnostics with PING. |
