This page provides power reset entry configurations. The entry is used to control the power reset time on PoE port. It is allowed to create at maximum five entries for each PoE port.
Object | Description |
Delete | Check to delete the entry. The designated entry will be deleted during the next save. |
Day | Checkmarks indicate which day are members of the entry. Check or uncheck as needed to modify the entry. |
Time (hh:mm) | hh - Select the hour. mm - Select the minute. |
Buttons | |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
