Configure the ACL parameters (ACE) of each switch port. These parameters will affect frames received on a port unless the frame matches a specific ACE.
Object | Description |
Port | The logical port for the settings contained in the same row. |
Policy ID | Select the policy to apply to this port. Valid values are 0 – 255. The default value is 0. |
Action | Select whether forwarding is permitted (“Permit”) or
denied (“Deny”). The default value is Permit. |
Rate Limiter ID | Select which rate limiter to apply on this port. The
allowed values are Disabled or the values 1 through 16. The default value is Disabled. |
Port Redirect | Select which port frames are redirected on. The
allowed values are Disabled or a specific port number and it can't be set
when action is permitted. The default value is Disabled. |
Mirror | Specify the mirror operation of this port. The
allowed values are:
Logging | Specify the logging operation of this port. Notice
that the logging message doesn't include the 4 bytes CRC. The allowed values
are:
The default value is Disabled. Note: The logging feature only works when the packet
length is less than 1518(without VLAN tags)
and the System Log memory size and logging rate is
limited.
Shutdown | Specify the port shut down operation of this port.
The allowed values are:
The default value is Disabled. Note: The shutdown
feature only works when the packet length is less than 1518(without VLAN
tags).
State | Specify the port state of this port. The allowed
values are:
The default value is Enabled. |
Counter | Counts the number of frames that match this ACE. |
Buttons | |
Refresh the page immediately. Any non-committed changes will be lost. |
Clear the counters or dynamic entries. |
Save changes. |
Undo any changes and revert to previously saved values. |
