General Settings |
Enable Loop Protection |
Controls whether loop protections is enabled (as a
whole). |
Transmission Time |
The interval between each loop protection PDU sent on each
port. Valid values are 1 – 10 seconds. |
Shutdown Time |
The period (in seconds) for which a port will be kept
disabled in the event of a loop is detected (and the port action shuts down the
port). Valid values are 0 – 604800 seconds (7 days). A value of zero will keep a
port disabled (until next device restart). |
Port
Configuration |
Port |
The switch port number of the port. |
Enable |
Controls whether loop protection is enabled on this switch
port. |
Action |
Configures the action performed when a loop is detected on a
port. Valid values are Shutdown Port, Shutdown Port and Log or Log Only. |
Tx Mode |
Controls whether the port is actively generating loop
protection PDUs, or whether it is just passively looking for looped PDUs. |
