SNMP Communities
Configure SNMPv3 community table on this page. The entry index key is Community.
Object Description
Delete Check to delete the entry. It will be deleted during the next save.
Community Indicates the community access string to permit access to SNMPv3 agent. Valid string length is 1 – 32, and the allowed content is ASCII characters from 33 – 126. The community string will be treated as security name and map a SNMPv1 or SNMPv2c community string.
Source IP Indicates the SNMP access source address. A particular range of source addresses can be used to restrict source subnet when combined with source mask.
Source Mask Indicates the SNMP access source address mask.
Buttons
Add a new entry.
Save changes.
Undo any changes and revert to previously saved values.
