Each page shows up to 999 table entries, selected through the entries per page input field. When first visited, the web page will show the beginning entries of this table.
The Level input field is used to filter the display system log entries. The Clear Level input field is used to specify which system log entries will be cleared. To clear specific system log entries, select the clear level first then click Clear.
The Start from ID input field allows you to change the starting point in this table. Clicking Refresh will update the displayed table starting from that or the closest next entry match.
In addition, these input fields will, upon a Refresh, assume the value of the first displayed entry, allowing for continuous refresh with the same start input field.
The button will use the last entry of
the currently displayed table as a basis for the next lookup.
When the end is reached,
No more entries shows in the displayed table. Use the
button to start over.
Object | Description |
ID | The identification of the system log entry. |
Level | The level of the system log entry. Info: The system
log entry is belonged information level.
Time | The occurred time of the system log entry. |
Message | The detail message of the system log entry. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Clear all statistics or dynamic entries. |
Update the table ending at the last entry currently displayed. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
Update the table ending at the last available entry. |
