Configure RMON Statistics table on this page. The entry index key is ID.
Object | Description |
Delete | Check to delete the entry. It will be deleted during the next save. |
ID | Indicates the index of the entry. Valid values are 1 – 65535. |
Data Source | Indicates the port ID which wants to be monitored. If in stacking switch, the value must add 1000*(switch ID - 1). For example, if the port is switch 3, port 5, the value is 2005. |
Buttons | |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
