Configure the rate limiter for the ACL of the switch.
Object | Description |
Rate Limiter ID | The rate limiter ID for the settings contained in the same row. |
Rate | The rate range is located 0-3276700 in pps. Valid values are 0 - -1, 0, 0, 0, ..., 3276700 in pps or 0, 100, 200, 300, ..., 1000000 in kbps. |
Unit | Specify the rate unit. Valid values are:
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
