Each page shows up to 999 entries from the MAC table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the MAC Table. The first displayed will be the one with the lowest VLAN ID and the lowest MAC address found in the MAC Table.
The Start from MAC Address and VLAN input fields allow you to select the starting point in the MAC Table. Clicking the Refresh button will update the displayed table starting from that or the closest next MAC Table match. In addition, the two input fields will, upon a Refresh button click, assume the value of the first displayed entry, allowing for continuous refresh with the same start address.
The will use the last entry of the
currently displayed VLAN/MAC address pairs as a basis for the next lookup. When the end
is reached, No more entries shows in the displayed table.
Use the
button to start over.
Object | Description |
Switch (stack only) | The stack unit where the entry is learned. |
Type | Indicates whether the entry is a static or a dynamic entry. |
MAC Address | The MAC address of the entry. |
VLAN | The VLAN ID of the entry. |
Port Members | The ports that are members of the entry. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Clear all statistics or dynamic entries. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
