The IP subnet-based VLAN entries can be configured here. This page allows for adding, updating and deleting IP subnet-based VLAN entries and assigning the entries to different ports. This page shows only static entries.
The maximum possible IP subnet-based VLAN entries are limited to 128.Object | Description |
Delete | To delete an IP subnet-based VLAN entry, check this box and click save. The entry will be deleted in the stack. |
VCE ID | Indicates the index of the entry. It is user configurable and valid values are 0 – 128. If a VCE ID is 0, application will auto-generate the VCE ID for that entry. Deletion and lookup of IP subnet-based VLAN are based on VCE ID. |
IP Address | Indicates the IP address. |
Mask Length | Indicates the network mask length. |
VLAN ID | Indicates the VLAN ID. VLAN ID can be changed for the existing entries. Valid VLAN IDs are 1 –4095. |
Port Members | A row of check boxes for each port is displayed for each IP subnet-based VLAN entry. To include a port in an IP subnet-based VLAN, check the box. To remove or exclude the port from the IP subnet-based VLAN, make sure the box is unchecked. By default, no ports are members, and all boxes are unchecked. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Undo the addition of the new entry or server. |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
