This page allows you to configure the basic QoS DSCP Translation settings for all switches. DSCP translation can be done in Ingress or Egress.
Object | Description |
DSCP | Maximum number of supported DSCP values are 64 and valid DSCP values are 0 – 63. |
Ingress | Ingress side DSCP can be first translated to new DSCP before using the DSCP for QoS class and DPL map. There are two configuration parameters for DSCP Translation:
Translation | DSCP at Ingress side can be translated to any of (0 – 63) DSCP values. |
Classify | Click to enable Classification at ingress side. |
Egress | There are the following configurable parameters for Egress side:
Remap DP0 | Select the DSCP value from select menu to which you want to remap. DSCP valid values are 0 – 63. |
Remap DP1 | Select the DSCP value from select menu to which you want to remap. DSCP valid values are 0 – 63. |
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
